It is currently Wed Jan 23, 2019 3:54 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
 Post subject: Re: trans question.
PostPosted: Wed May 10, 2017 5:46 pm
thats what I was thinking... but the rotors (galant ones) should work right?
PostPosted: Thu May 11, 2017 11:32 am
I'm confused, have you looked to see if you have rear discs from the factory? Like I said, if it has abs it already has rear discs. Don't think the GVR4 rotors will work because the wagons have the e-brake within the hub, kinda like drum brakes. Probably shares rotors with the 94 Galant GS.
95 Eagle Summit DL coupe
15 Mitsubishi Mirage ES hatch
