It is currently Mon Oct 20, 2025 10:22 pm
PostPosted: Sat Nov 07, 2015 12:02 pm
Hey guys I met a few summit guys art the shootout this year and I Was wondering if anyone had info on using a dsm ecu or swapping in a dsm harness. Its dohc swapped but still has the distributor. Any help will be greatly appreciated
PostPosted: Tue Nov 10, 2015 2:33 pm
ewe thats interesting. I wanted to convert to dohc as a first step. I was hoping the distributor would work so i could run it on the factory ecu first. as far as harness goes there are enough wires on the expo harness to convert the harness to turbo spec. so thats one way. then of course you can use a turbo harness and splice that in as well.
PostPosted: Tue Nov 10, 2015 2:46 pm
Some info here: viewtopic.php?f=100&t=37330
