It is currently Tue Oct 21, 2025 1:16 am
 Post subject: WTB: Manual swap parts.
PostPosted: Wed Apr 16, 2014 8:40 pm
I need the entire clutch pedal / brake pedal assembly along with clutch master cyl. to finish my manual swap for my 92 AWD LRV, let me know if anybody has a parts car that I could get the swap parts from and how much. I looked all over the web and wasnt able to find anything locally either, which is actually why I just registered here!
Thanks in advance,
PostPosted: Wed Apr 16, 2014 10:19 pm
Owner/Admin
Please post your location in your user control panel. The parts you're asking for are hard to come by.
PostPosted: Sat Apr 19, 2014 1:03 pm
Did you also swap your rear end? Auto and 5sp use different ratios.
PostPosted: Mon Apr 21, 2014 12:31 pm
I have a 1.8L Auto LRV which I understand has the 3.545 rear end for more torque from the smaller engine. The 2.4L Expo's had the 3.3 gearing.
Thanks for lookin' out, though!
PostPosted: Wed May 14, 2014 1:01 pm
Almost right. Looking at my '94 workshop manual, rear diffs ...
* the 1.8 M/T has a 2.846:1 and a W5M31 transmission
* the 1.8L A/T (model not listed in manual) and 2.4L M/T (W5M33) has a 3.454:1
* the 2.4L A/T (W4A32) has a 3.307:1
The 2.846 diff case is physically smaller than the 3.454 / 3.307. The crown wheel is smaller.
Look on the firewall plate for the transmission model. The 1.8L may well have a W4A32, but it's not the same as the W4A32 in the 2.4L A/T. At least the front diff ratio will be different. possibly also the transfer case ratio as well.
The 2.4L models have approx 50/50 torque split front/rear, while I believe the 1.8L models have approx 60/40 split, biased to the front.
PostPosted: Tue Dec 23, 2014 7:27 pm
did you get this swap done? do you happen to still have the a/t tranny?
