It is currently Fri Mar 29, 2024 12:28 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Sat Feb 28, 2015 2:29 pm
Bringing this back from 2 years dead. Did you ever drive it? I know you said exhaust is still needed but I have driving cars on just downpipe.
I think all of us would like to see where you are at from the 2 years of no post.
I've been updating my last post recently, still at my friends shop with promises of being finished soon. its almost complete just need to do the wiring, still haven't driven it :x
PostPosted: Wed Apr 01, 2015 2:46 pm
Online
was looking over this thread again and wow 3 years and still havent driven it.. that sucks man. hope its running soon.
PostPosted: Thu May 07, 2015 8:30 pm
new clutch and components are in. Buttoning the rest up slowly, should be a few weeks, but no promises haha
PostPosted: Fri May 08, 2015 4:57 pm
Great! Now when can you make it by the RobSport to make a custom sway bar?:)
PostPosted: Fri Jan 22, 2016 3:27 pm
Currently doing the same swap.
may I ask how you modified your stock van engine mount to work? Did you have to cut and weld?
As I found out it was too short for the 1G 6 bolt talon engine. I was hoping to buy one off another car that would bolt on.
Cheers,
Ricky
PostPosted: Wed Jan 27, 2016 11:43 am
Cheers,
Ricky
my van was a 92 manual. I used all my factory engine mounts. nothing needed to be modified.
PostPosted: Tue Jun 07, 2016 11:57 am
question for the guru's my mechanic says that the trans is locked up with the ACT in it. he wants to put the stock clutch back in or have me get a 1g trans. what do you guys think?
PostPosted: Tue Jun 07, 2016 1:20 pm
Your transmission is the w5m31, correct? Not sure why that would have an issue with the ACT clutch
PostPosted: Tue Jun 07, 2016 2:28 pm
I never drove the car so maybe it had a bad tranny to begin with. All i know about it is that it didn't run when i got it. so basically nothing. thinking about getting another tranny to move forward.
PostPosted: Tue Jun 07, 2016 7:03 pm
Maybe he has the wrong pressure plate/flywheel combo sitting in the mix right now? Some flywheels are flat, some are stepped?
I'm curious as to what portion of the clutch or whatever he is poking the stick at. Your trans is AWD, based upon that code correct?
Shouldn't be any issue ... but maybe the viscous coupler/transfer case locked up?
Does the vehicle roll just fine with the trans out of gear?
PostPosted: Thu Jun 09, 2016 12:16 am
he said he installed the clutch and was pushing the van around the shop then one day it locked up and wouldn't move.
PostPosted: Thu Jun 09, 2016 10:21 pm
That is strange.
PostPosted: Mon Jun 05, 2023 12:47 pm
ok just got my van back from my mechanic after way too long, its a basket case now and trying to see if i can either A get help from someone in so cal or just sell it as is, im located in san pedro about 25min from los angeles
https://ibb.co/SNcJVcr
https://ibb.co/zZfNfvn
http://4g61t.org/gallery/v13w.php?gal=o ... ia/images/
PostPosted: Tue Dec 19, 2023 1:15 am
anyone still active on here? gonna start this build again in the next few weeks and would lie to ask some questions as I'm sure some will come up
PostPosted: Mon Jan 29, 2024 6:31 pm
just got another project but way easier then the usdm van, 1994 rvr 33k miles straight from japan, has a blown head gasket and some shoddy work but it should be straight forward, ill post pics when its done
