It is currently Tue Oct 21, 2025 10:07 am
Post new topic  Reply to topic  [ 178 posts ]  Go to page Previous 13 4 5 6 712 Next
PostPosted: Sat Dec 31, 2011 10:18 am
Bummer, I had a lengthy search for a cover. I finally found one, but it wasn't cheap or easy. And now, I have to fix all the little scratches in it.
I am also debating if I should add holes to aid FMIC cooling?
Has anyone done it on a wagon?
PostPosted: Sat Dec 31, 2011 6:48 pm
These are so ugly. I think you can do better. Youre going to have to blaze the trail on this one. I couldnt think of an easy way to do it or i would have done it already. Some custom work would be required to make a bigger hole look factory, or some REAL precise work with the drill and a jigsaw to put a bunch of slotted holes above the stock opening. But it would unfortunately would only look stock from 20 feet away. Up close would be hack.
PostPosted: Sun Jan 01, 2012 2:02 am
I actually like the base front cover that you show above (without the spoiler on the bottom). But this is a mute point, these front bumpers are very rare and expensive (~$500 for the cover and then ~$500 to ship it here from Asia, Australia or NZ) So I am not even going to consider it :(.
I know how to properly cut the bumper, I am just curious if anyone has done it, so that I can see the way it looks ;)
PostPosted: Thu Jan 05, 2012 11:28 am
if you need some ideas on how to cut it these pics might offer some. id like to look as stock as possible but if i could find a JDM front bumper cover like the one pictured below (for a decent price and minus the crazy grill protector in the second pic) i wouldnt mind having one. probably not a necessity by any means. you should measure your intake air temps and see if you even need to do any cutting...it might not make a big difference.
PostPosted: Thu Jan 05, 2012 1:15 pm
With 14b, intake temps are extremely low (75-90F). From my DSM experience, the real problem is with the radiator being blocked by a hot intercoler and consenquent overheating. But this might not be a problem on a Summit, which has an actual radiator grill.
The only reason why I am considering doing this now, is because I am doing bodywork on my new bumper cover, so timing is right.
But I have been considering making slots that are found that first car.
PostPosted: Thu Jan 05, 2012 4:27 pm
Wonder if the Subaru bumper will fit the wagons like it does on the 3g csm's? It looks better and has a larger cutout stock for a fmic.
PostPosted: Thu Jan 05, 2012 6:55 pm
i like the expo's bumper and grill in the first pic, whats that from?
PostPosted: Fri Jan 06, 2012 12:04 am
some thing like this
http://www.nichibocars.com/vehicle.php?StockNo=226906
PostPosted: Fri Jan 06, 2012 7:45 pm
I wasn't going to do it, but I am weak :) I ended up making 3 rectangular cuts with rounded corners:
I will update this thread when I get it installed on the Summit. The plan is have black pastic mesh behing it.
PostPosted: Fri Jan 06, 2012 8:07 pm
Im impressed. That looks great. It will look still stock to most people from even fairly close up. You did a very precise job cutting that out as well.
PostPosted: Fri Jan 06, 2012 8:15 pm
Thanks! I drilled four corner holes (using 1" hole saw) and then connected them with straight lines, using a cutting tool (which pretty much melted its way through the plastic).
PostPosted: Fri Jan 06, 2012 8:33 pm
ill second that, looks great, i want to do something similar as well.
PostPosted: Sat Jan 07, 2012 1:08 pm
Very nice!
PostPosted: Sat Jan 07, 2012 7:10 pm
I'm digging the cut bumper. I think it will look really good.
PostPosted: Sun Jan 08, 2012 11:49 am
great job! very impressed with how clean and straight it looks. post a pic when its installed please!
