| Technical Specifications and parts weights (addition) http://4g61t.org/forum/viewtopic.php?f=10&t=99 |
| Author: | Guest [ Wed Dec 31, 1969 7:00 pm ] |
| Post subject: | Technical Specifications and parts weights (addition) |
This information was obtained directly from the August 1989 Car & Driver magazine, where it made, C/Ds TEN BEST LIST FOR 1989. THE SUBJECT: 1989 Mirage Turbo hatchback. Boasts 29% more hp, & 16% more torque than previous SOHC 1.6-liter turbo, it also has a 1.9" wider body than before. PRICE AS TESTED:$13,550 options on test car: Base Mitsubishi Mirage Turbo $11,969; A/C $744; sound system upgrade $552: freight $285 SOUND SYSTEM: Mitsubishi AM/FM-stereo radio/cassette, 6-speakers ENGINE: Type....Mitsubishi turbocharged 4G61 4-in-line, iron block, & aluminum head Bore x stroke....3.23 x 2.97 in, 82.0 x 75.5mm Displacement....97 cu in, 1595cc Compression Ratio....8.0:1 Engine-control system....Mitsubishi electronic with port fuel injection Emission controls....3-way catalytic converter, feedback fuel-air-ratio control, EGR Turbocharger....Mitsubishi TDO4-11b Waste gate....integral Max boost pressure....12.1psi Valve gear....belt-driven D-O-H-Cams, 4 valves per cylinder, hydraulic lifters Horsepower (SAE net)....135 hp @6000rpm Torque (SAE net)....141 lb-ft @3000rpm Redline....7000rpm DRIVETRAIN: Transmission....5-speed Final-drive ratio....4.32:1 Gear---Ratio---Mph/1000rpm--Max. test speed I---3.08---5.1--35mph(7000rpm) II---1.83---8.5--60mph(7000rpm) III---1.24---12.6--88mph(7000rpm) IV---0.90---17.3--118mph(6800rpm) V---0.73---21.4--121mph(5650rpm) *The car is gear limited to approximately 153mph. DIMENSIONS AND CAPACITIES: Wheelbase....96.7" Track, F/R....56.3"/56.3" Length....170.1" Width....65.7" Height....55.1" Ground clearance....3.5" Curb weight....2545lbs Weight distribution, F/R....64.1/35.9% Fuel capacity....13.2gal Oil capacity....4.2qt Water capacity....5.5qt CHASSIS/BODY: Type....unit construction Body material....welded steel stampings INTERIOR: SAE volume: Front seat....50 cu ft Rear seat....35 cu ft Trunk space....10 cu ft Front seats....bucket Seat adjustments....fore & aft, seatback angle General comfort....poor-fair-GOOD-excellent Fore-and-aft support....poor-fair-GOOD-excellent Lateral support....poor-fair-GOOD-excellent SUSPENSION: Front....Independant strut located by a control arm, coil springs, anti-roll-bar Rear....rigid axle integral with two trailing arms, Panhard rod, coil springs, anti-roll bar STEERING: Type....rack-and-pinion, power assisted Turns lock-to-lock....2.9 Turning circle curb-to-curb....32.2 ft BRAKES: Front....10.4x0.9" vented disc Rear....10.4x0.4" non-vented disc Power assist....vacuum WHEELS AND TIRES: Wheel size....5.5x14" Wheel type....cast aluminum Tires....Yokohama A-406 performance tires on 195/60HR/14 Test inflation pressure, F/R....29/29psi CAR AND DRIVER TEST RESULTS: Acceleraton: 0-30mph/2.5sec. 0-40mph/3.9sec. 0-50mph/5.7sec. [b:2t5v53qi]0-60mph/7.8sec. [/b:2t5v53qi] 0-70mph/10.7sec. 0-80mph/14.0sec. 0-90mph/17.9sec. 0-100mph/23.1sec. Top-gear passing time: 30-50mph/12.3sec. 50-70mph/9.8sec. [b:2t5v53qi]Standing ¼-mi. time 15.9sec. @87mph [/b:2t5v53qi] Top speed....121mph BRAKING: 70-0 @impending lockup....196ft Modulation....poor-fair-GOOD-excellent Fade....NONE-moderate-heavy Front-rear balance....poor-FAIR-good HANDLING: Roadholding, 300-ft-dia skidpad....0.78g Understeer....MINIMAL-moderate-excessive COAST-DOWN MEASUREMENTS: Road horsepower: 30mph/6hp 50mph/14hp 70mph/30hp FUEL ECONOMY: EPA city driving....23mpg EPA hwy driving....29mpg Car & Driver observed fuel economy....20mpg INTERRIOR SOUND LEVEL: Idle....48dBA Full-throttle acceleration....84dBA 70-mph cruising....73dBA 70-mph coasting....72dBA *Posted by: MIRAGEDOHCTURBO |
| Author: | Flying Eagle [ Wed Jan 23, 2008 8:47 am ] |
| Post subject: | |
Sinisfun posteed this January 2008, it should be very accurate as to the weights of stock pieces that can be removed from the car for weight loss at the track. Thread this info was pulled from: Cody Dyck - 1989 Dodge Colt (4G63t) Quote: Well here we go:
Drivers Seat (Hyundai seats): 36.6lbs Passenger Seat (Hyundai seats): 33.6lbs Rear seat back: 16.6lbs Rear seat base: 9.6lbs Rear seat interior panels & rear shoulder belts x 2: 12lbs Rear seat belt female ends (all of em): 2lbs Misc. interior pieces (Floor mats, etc.): 10.8lbs Main carpet: 14lbs (I was expecting more) Hatch carpet & spare tire cover: 9.8lbs Rear hatch hanging cover: 5.6lbs Spare tire, jack & tire removal tools: 35.2lbs All for a grand total of 204.8lbs of weight reduction. New front seats have to go in, but I'll try and find some that are significantly lighter. Does anyone know how much the stock 3g Colt seats weigh? So if I put the Hyundai driver seat back in my car is now at 2321lbs. Update: Well I took out over 20lbs of sound deadening and a couple other things, I went out with the Gtech and ran a 14.8 @ 96mph, killing my previous best from a couple days ago of 15.7 @ 8xmph. Man is it loud inside now. |
