Datalogging http://4g61t.org/forum/viewtopic.php?f=10&t=7414 |
Page 9 of 9 |
Author: | Pixt3r [ Sat Feb 05, 2005 12:08 pm ] |
Post subject: | |
is there a PC or laptop software for the MMcd ??? I have the palm software but I'm waiting for my usb/db9 cable to be able to connect my data cable. tx jp |
Author: | switch [ Sat Feb 05, 2005 6:32 pm ] |
Post subject: | |
The laptop software is not MMcd. But you can get a program that extropolates all the mmcd data into an excel table. On the vr4 australia forums, there is a guy who made a palm emulator for the pc but you have to be a financial member of the club to get a copy of it. www.clubvr4.org Mike |
Author: | monsterbishi [ Thu Mar 24, 2005 7:19 am ] |
Post subject: | |
There's something people can do so that one cable can be used on both palm & laptop, just make a crossover gender bender, I just went tx - rx and vice-versa, along with ground to ground, and encased it in resin. |
Author: | $50colt [ Tue May 17, 2005 6:35 pm ] |
Post subject: | |
Monsterbishi, I pm'd you about the program for pc's and I just wanted to post in case it was deleted when the server was down. It sounds like it won't work on a mac. Does anyone know if there is a free version for macs? I have a macintosh power book. |
Author: | monsterbishi [ Tue May 17, 2005 7:42 pm ] |
Post subject: | |
afaik, no such software exists for a mac... unless it has some real good pc emulation software that allows for serial port use as well. |
Author: | Tsukasa [ Tue May 17, 2005 11:36 pm ] |
Post subject: | |
I just received my palm whit pocketlogger and i did a little run here's some number.. at 10 psi on 94 octane rpm:5937 knock:0 timing:24 deg air flow:1575 hz o2:0.92 volts inj p/w:15.13 ms isc:71 steps o2 trim:100% fuel trim hi:81% fuel trim mid:81% fuel trim low:85% wb o2:18.90 i read that when the fuel trim a lower than 100% its because im in a rich condition ? .. |
Author: | monsterbishi [ Wed Jul 27, 2005 5:32 pm ] |
Post subject: | |
for reference, the schematic images have been moved, so here's the palm one hosted on my local mitsu club server: for a laptop cable you just need to use a db9 female plug instead with pins 2 & 3 swapped. |
Author: | bosco2023 [ Mon Sep 12, 2005 10:52 pm ] |
Post subject: | |
Is there any PDA's that you guys would not buy? will one of the new 25 dollars ones work off ebay, or how about the ones that look like mini computers? seems to me that they just have bigger displays... i dunno. on the site where you down load the free software for the pda's, i have seen the compadibility charts but, does that mean they are the only ones in the world that will work, or i guess maybe you get what you pay for? |
Author: | SpinMasta11 [ Mon Sep 12, 2005 11:15 pm ] |
Post subject: | |
I bought a palm m100 off ebay with the serial cable and palm windows CD for $35 shipped I believe, works decent, well enough to tune the car with. |
Author: | d1verDSM [ Tue Oct 18, 2005 9:10 pm ] |
Post subject: | |
well .. dont buy a visor delux , and dont buy anything with an os that is not upgradable. And also make sure there is a serial cadle available for it !1 |
Page 9 of 9 | All times are UTC-05:00 |
