It is currently Fri Apr 26, 2024 7:54 am
PostPosted: Mon Mar 05, 2007 3:53 pm
ColtMAX wrote:
After browsing the archives i came to the conclusion that we do not have anough information on brakes for the C53A Mirage/Colt.
So here are my findings:
Rotors
Brembo Oem Replacement
FR: 25341
RR: 25165
Pads
Hawk HP + Pads
FR: H213H.626
RR: N/A
Stainless Steel Brake Line Kit
Goodridge G-Stop
4 corners: 26043
**If you have other brands and part numbers please post them and I will update this list.
Updated by the site admin circa 2002.
The stock brake pad codes are Front: D328 and Rear: D329. These are federal assigned codes given to the pads that are used by all manufacturers. You can use the code to cross reference pads at different companies.
[b:bsk70jmr]Upgraded Pads[/b:bsk70jmr]
You can purchase Axxis Metal Master pads from most brake pad suppliers. You can also have [url:bsk70jmr]http://www.carbotecheng.com/[/url:bsk70jmr] build you a set of pads if you send them some old ones.
[b:bsk70jmr]Stainless Steel Lines[/b:bsk70jmr]
DOT Approved SS Brake Lines are available from [url:bsk70jmr]http://www.diamondstarspecialties.com[/url:bsk70jmr].
Cost was only $109.00 for all 8 lines. These are specifically made for the mirage hatch. I'm not certain if they will work on the sedans.
*Note, these may not work with the nonturbo's because of differences in the brake systems. Can anyone confirm this.
