It is currently Sat Jun 01, 2024 4:04 pm
Computer codes for Mitsubishi computers
1 ECU Dead
9 Normal
11 Oxygen sensor
12 Air Flow sensor
13 Intake Air temperature sensor
14 Throttle Position Sensor
15 Idle Speed control
21 Coolant Temp Sensor
22 Crank angle Sensor
23 TDC Sensor
24 Vehicle Speed Sensor
25 Barometric pressure sensor (MAS)
31 Knock Sensor
32 MAP sensor faulty
36 Ignition Timing adjustment failure
39 Front oxygen sensor
41 Fuel injector failure
42 Fuel pump or circuit
43 EGR
44 Ignition Coil
55 Idle Air control
59 Rear oxygen sensor
61 ECM and transmission interlock
62 Induction control valve
69 Right rear oxygen sensor
71 Traction control
72 Traction control
