It is currently Fri May 03, 2024 6:00 am
PostPosted: Wed Jan 11, 2006 11:31 pm
First off, are links to gauges you can print out and make or show, a printing place to have them produce some "professional" faces for you.
I have the pictures uploaded to Imageshack now.
Saved them!!!
Photobucket dump of all the gauge cluster faces!!!!!
*Warning*
A couple words before you print off a Turbo cluster face for a Non-Turbo transmission setup - You need to get a different cluster to accommodate the calibration difference - the gears in the transmissions are the same however. So putting a Turbo cluster in a Non-Turbo car is perfectly acceptable, but not applicable to put a Turbo cluster face on a Non-Turbo gauge cluster.
Also to note, is that changing the top speed range and or putting a in a cluster of lower mileage may be prohibitive in your local jurisdiction so be forewarned about that. If this is just for personal use, you may be OKAY.
*End Warning*
North American, United States Turbo CSM Imperial setup:
- 145 MPH Speedometer
6380x5904 resolution
640x592 resolution
- Tachometer 7000 RPM Redline
6376x5912 resolution
640x593 resolution
Australian/New Zealand, Cyborg Metric setup:
- 240 KPH Speedometer
- Tachometer 7500 RPM Redline
- Australian 1989 Lancer Non Turbo White Face Cluster 200 KMH 6000 RPM Redline
Europe, Germany Factory NA Black Face, Metric Setup:
coltanostra's gauge faces: German 4G15 8V/12V NA, 5 Speed, 200 KMH Speedometer, 6000 RPM Redline Tachometer
- 200 KMH Speedometer
- 6000 RPM Redline Tachometer
Secondly, we have Gauge faces that show you what the other countries and their imported vehicles have come equipped with originally, or which have had aftermarket faces installed.
North America, United States:
United States, Mirage GS, Factory Imperial setup:
- 1.6L NA, Automatic, 145 MPH, 7000 RPM Redline
United States:
Gage's (RIP) gauges:
- 125 MPH Speedometer, 6000 RPM Redline
United States:
summitman's custom gage faces:
- Speedometer
Tachometer
United States:
- Red White and Blue 125 MPH:
- Red White and Blue 125 MPH: Mitsubishi Mirage Labels
North America, Canada:
- Ed Wong's custom Metric gauges (Produced most likely by Gage .... ?)
New Zealand and Australia:
New Zealand, Mitsubishi Mirage Colt (yes Mirage Colt) 1991 Metric setup:
snowdevl's factory gauge faces
- 4G61 NA, 5 speed, 180 KMH, 7000 RPM Redline start, 7500 RPM FULL Redline
New Zealand, Mitsubishi S Swift R 1991, Metric setup:
- 4G61 NA, Auto, 180 KMH, 7000 RPM Red Line start, 7500 RPM FULL Redline
New Zealand, Mitsubishi Cyborg 1988, Metric setup:
- 4G61 NA, 5 Speed, 180KMH, 7000 RPM Redline start, 7500 RPM FULL Redline
Europe (Britain, Germany, Denmark, Sweden, Finland, Croatia, etc.):
Finland, Colt GTi, Metric Setup:
Most likely Non Turbo vehicle with Turbo aftermarket gearing faces
- 240 KMH, 7000 RPM Red Line start, 7500 RPM FULL Redline
Germany, Colt Metric setup:
coltanostra's gauges:
- Colt GTi 4G61/4G67 Factory Metric setup, 5 Speed,240 KMH Speedometer, 7000 RPM Redline Start, 7500 RPM FULL Redline
- 4G13 8V Factory Metric setup, 200 KMH Speedometer only, with Gas and Temp gauges
Germany, Colt/Mirage Metric setup:
Non Turbo, 200-210 KMH, 7500 RPM Redline (Showing might not be factory spec - pending)
- Picture 1
- Picture 2
- Picture 3
More German Gauge face swaps, Colt GTI Metric setup:
Non Turbo Colt Mirage, 260 KMH Speedometer, Tachometer 6500 RPM Red Line start, 7500 RPM FULL Redline (Showing might not be factory spec - pending)
- GTI Pic 1
- GTI Pic 2
- GTI Pic 3
- GTI Pic 4
MORE TO COME, teh time is now Sunday, Jan. 15, 2006 1:33AM :o
PostPosted: Wed Jan 15, 2014 5:27 pm
Uploaded Gauge Face pics to Imageshack. Saved!!!!!
Tons of pics if you want someone to make overlays worth a grain of salt and accuracy.
Be sure to read the post about which ones jive with which clusters. :wink:
They can only go one way.
PostPosted: Mon Nov 09, 2015 8:24 pm
Link is now active at the top of the page, first post, first link.
